Frascao's avatar
Frascao
Tutor
Nov 26, 2016
Steamlink frame rate low
CIAO
I bougth steamlink but i can't use it well because the rate is very slow.
Anibody can help me?
Pc-router: cable connection
Router-steamlink: cable connection
System information:
MB: Asus 1366 P6X58D- E (X58)
CPU: Intel Core i7 LGA1366 950 3.06GHz 8Mb Boxed
RAM: CORSAIR 12GB (6x2GB) DDR3 1600 XMS3 CL9
GPU: Msi GTX960
AUDIO: CREATIVE Sound Blaster X-FI Titanium PCIe Retail
ALI: CoolerMaster 850W Silent Pro M850 80Plus, modulare
HD: SEAGATE Barracuda 7200.12 1TB SATA2 ST31000528AS
SO: WIN10 (uprgrade da WINDOWS 7 PROFESSIONAL 64 BIT OEM)
MONITOR: Samsung LED 23" PX2370 5.000.000.0:12ms DVI-I HDMI
ROUTER: Netgear D7000
INTERNET: down 13 Mbps, up 0,9 Mbps
I attached some screenshot about my situation.
Another question: why the blue line in the home web map between router and steamlink? Any router firewall setting to change?
Many thanks.
CIAO
Stefano
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Frascao
    Have you tried the simple things such as swap out the Ethernet cable or move the cable to a different port on the router?
    DarrenM
    • Frascao's avatar
      Frascao
      Tutor
      Yes.
      I tried both possibilitis but nothing.
      Other ideas?
      CIAO
      Stefano
