ladyk811's avatar
ladyk811
Suddenly mediacom modem not communicating with router
I do have an appointment for my cable company to come out on Friday.  However, I am still working on trying to fix this.  My modem work fine, I have tested out with ethernet cord and my laptop.  However, my router is not getting an internet connection.  I can look at the available wifi networks and it shows with bars and all but I can't connect to it.  It was working before with no issue, and then all of a sudden its not working.  I think my router is maybe 2 or 3 years old.  Any suggestions or ideas?
  • plemans's avatar
    Have you tried a factory reset on the devices?
    try in this order.
    1. Factory reset the device. Don't set it up yet.
    2. Power off all devices.
    3. power on modem. leave it a couple minutes to fully boot.
    4. Power on your router and go through your setup.
    here's your support page for the device.
    https://www.netgear.com/support/product/WNR2000v3.aspx
    • ladyk811's avatar
      ladyk811
      I should have mentioned I have tried everything from reset to unplugging things in all orders.  I have tried leaving everything unplugged and then reconnecting.  I should have mentioned that inititally.
    • ladyk811's avatar
      ladyk811
      One more thing.  I did come across the support page when this first started and I did try those steps as well.
      • plemans's avatar
        when you hardwire into the extender, you can rerun the setup wizard. It doesn't have to be reset.
        1. Did you try the factory reset from the extenders menu?
