Screwthis
Nov 11, 2016Aspirant
Support for c6300
Their support system does not work: I copied & pasted the serial #, and it came back "invalid" (multiple, multiple, multiple times). I typed in the serial #, eliminating the capital letters- same thing, multiple times.
Plus, the damn router/modem is defective.
- clithesProdigy
What is the problem, maybe this community will have the answer?
- ScrewthisAspirant
Thanks for your reply. This post got posted in the wrong place, so I posted again in Cable Modems & Routers > Troubleshooting.
The problem: signal gets dropped intermitently, and varies from 0 > 140 mbps.
I took the 3 week old modem/router back to Best Buy- their return policy states I only had 15 days (I'll never go back).
So, I turned to Netgeat Support. I registered my device. Got an email confiming that- serial # included.
But when I have tried to engage Support, it will not take that serial #- keeps coming back, "invalid."
I posted here- like I said this post and one other.Yours is the only reply, two days later. I thought for sure Support would chime in, but.....crickets.
Screwthis wrote:Yours is the only reply, two days later. I thought for sure Support would chime in, but.....crickets.
This place is mostly user-to-user, with some input from a small team of Netgear folks. The official support teams doesn't hang out here.
Have you checked the support section for your device?
C6300 | Product | Support | NETGEAR
