geandsco
Jan 05, 2019Aspirant
switching to Xfinity voice
I have been using, succesfully, a Netgear C6220 modem/router formy Xfinity (Comcast) internet service. I am adding Xfinity voice, but the C6220 does not have a phone connection. Can I simply purchase...
vkdelta
Jan 16, 2019NETGEAR Employee Retired
C6220 cannot be connected behind CM500V
CM500V cannot be connected behind C6220.
If you want Voice service from comcast, you should either replace your C6220 with CM500V+Router or C7100V. both of them are bit of expensive options for you.
Alternatively, you can choose non-comcast voice service such as OOMA. It is not recommended by NTGR but just provided as option.
geandsco
Jan 17, 2019Aspirant
Thank you for the responses. I purchased the CM500V, put a splitter on the cable line and am using the CM500V as a stand alone voice modem. I left the C6220 as is, with the other side of the splitter going to it. Comcast said I may have lower than desirable power but so far so good.
- vkdeltaJan 18, 2019NETGEAR Employee Retired
yes, that option works as well.
note that CM500V has more DOCSIS channels. If you buy new router in future when technology changes, please connect it behind CM500V and not C6220.
