Bricked1234's avatar
Bricked1234
TFTP program reset CAX30
Hi I have attempted the TFTF fix, has not fixed the problem but noted a few things if anyone worked or has feedback.
General note
When I reset the router and the 2 ethernet cable light turns on my ethernet connection goes to identifying to unidentified network but once the 2 turns off it goes back to network cable unplugged. ( I am plugged into port 1, and when i plug into port 2 light 3 turns on)
Fix through windows command prompt
press enter after resetting for 30 seconds. (tftp -i 192.168.1.1 put CAX30-V1.4.11.2.bin)
Will pending for a period of time and then give "Connect request failed"
Tried about 10 times
Using the NMRP solution
nmrpflash.exe -i net5 -f CAX30-V1.4.11.2.bin in command prompt.
New window pops up says its looking for ethernet connection then
Advertising NMRP server on net5 ... |
Then "no response after 60 seconds bailing out"
This is said  short time after the 2 light turns off.
Any feedback?
Thanks
( did manually set the IP in TP4 like both instructions  told me)
