WalterEH's avatar
WalterEH
The router will not fully restore after internet service is disrupted and restored.
I have now had the same problem with two different CAX80's at two different homes.  The router will not fully restore after internet service is disrupted and restored.  Currently I am trying to fix one remotely.  It will connect to a Home Assistant device that's hard-wired to the router, but Wifi completely does not work.  Last time I fixed this, I had to reset the router and reconnect almost all wifi devices.  Internet service itself was OK.  I am able to reset the modem/router remotely using either Xfinity or the Netgear Nighthawk app, but nothing will restore wifi; nor can I connect to the router itself remotely to see if there are issues with the settings.
The reason I bought the CAX80's in the first place was to be able to reset both modem and router remotely (not just the modem); but this is worse than the prior state with a separate cable modem.
