rslobodian's avatar
rslobodian
Follower
Oct 02, 2017
Timeing out problem
Upgrade my Comcast service from 120 Mbps to 235 Mbps.
My C 6300 says transfer rate is 144 Mbps
Is this why I have time out problems and lots of 'hesitations'?
Netgear says C6300 will do up to 680 Mbps.
How do I fix the problem?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Rslobodian
    You may need to check with your ISP it may need a modem that has more downstream channels in order to get higher speeds. As for the timeouts what are you seeing in the modem logs?
    DarrenM
