osk-oak
May 08, 2019Aspirant
Troubleshooting Dropouts Netgear CM600
Thanks in advance for any help.
I have Xfinity Cable Internet.
I have a Netgear CM600 modem, Pakedge RK-1 Router, Ubiquiti Wifi.
The dropouts occur on both wired and wireless connections so I can rule out the wifi.
I am trying to troubleshoot it.
I tried replacing the modem with a surfboard and that didn't fix it.
I attach a shot of the dashboard in the netgear modem. Notice the errors. Does this tell anyone anything about the nature of my problem, or does anyone have any troubleshooting advice for me?
Thanks
josh
Check for any cable line splitters between the modem and ISP services.
Contact the ISP servcie and have them check there logs and signal up to the modem. If another modem exhibited same issues, then this would be a ISP service line issue.
- osk-oakAspirant
THANK YOU for the help.
If I may follow up...
Do you feel those errors show clear evidence of a problem on the line from my modem outward to the network?
I am just trying to conclusively narrow down the problem, as I have had the comcast techs out here before and given the intermittent nature of the error, it usually ends in them either throwing up their hands, or saying it's probably in my equipment.
Seems to have some uncorrectables.
You can tell them that you've tried two different modems and both exhibit the same thing.
Has to be something on there end.
