TonyLinguini
Oct 23, 2015Aspirant
Trying to use external MyBook for network backup
I tried to use my old MyBook to do thia and it would not show up. I tried a thumb drive and it showed up fine. So I researched on this site and found a different model suposedly compatible. I bought ...
DarrenM
Oct 26, 2015Sr. NETGEAR Moderator
Hello Tonylinguini
Have you tried to format the drive and make sure its NTFS and Fat32 file format?
DarrenM
TonyLinguini
Oct 26, 2015Aspirant
It was NTFS, but it was 3TB. I separated it to 2 - 1.5TB partitions and it saw it fine. However, it is not practical to use it for network backup because it is sl-o-o-o-o-w. Thank you.
- vkdeltaOct 26, 2015NETGEAR Employee Retired
- TonyLinguiniOct 27, 2015Aspirant
CG3000Dv2
- vkdeltaOct 27, 2015NETGEAR Employee Retired
generally NTFS is slow on the Cable gateways (since most of them use opensource NTFS-3G driver). what speeds are you seeing?
can you please try FAT or EXT formatted drives?
