TonyLinguini
Oct 23, 2015Aspirant
Trying to use external MyBook for network backup
I tried to use my old MyBook to do thia and it would not show up. I tried a thumb drive and it showed up fine. So I researched on this site and found a different model suposedly compatible. I bought ...
TonyLinguini
Oct 26, 2015Aspirant
It was NTFS, but it was 3TB. I separated it to 2 - 1.5TB partitions and it saw it fine. However, it is not practical to use it for network backup because it is sl-o-o-o-o-w. Thank you.
vkdelta
Oct 26, 2015NETGEAR Employee Retired
- TonyLinguiniOct 27, 2015Aspirant
CG3000Dv2
- vkdeltaOct 27, 2015NETGEAR Employee Retired
generally NTFS is slow on the Cable gateways (since most of them use opensource NTFS-3G driver). what speeds are you seeing?
can you please try FAT or EXT formatted drives?
Horribly slow. Connected to computer 20 minutes, through the router 6 hours. I am not interested in stepping backwards in format to make this work, please consider this answered.
