LitteGratz's avatar
LitteGratz
Turn the Nighthawk CAX80 into a Modem only
CAX80 - Nighthawk® AX8/8-Stream WiFi 6 Cable Modem Router
How do I set it up the CAX80 as just a Modem? My House is just to big and I want to do a Mesh Wifi system and use the unit as Modem only (no Wi-fi and no router)
Thanks,
Rob
  • plemans's avatar
    the CAX80 is a quite powerful router.
    I'd actually leave it in router mode and put the mesh system in access point mode.
    then just have the CAX80 use a different channel/ssid to prevent interference.
    That'd allow you to have both a backup wifi network as well as offload a few devices from the mesh system.
    • LitteGratz's avatar
      LitteGratz
      plemans Thanks for the suggestion.
      So if I use an Orbi Mesh System I can set each unit into Access Point mode? I have used Orbi in the past and I do not remember that option.
      Let me know if this is a question for a different forum.
      Thanks
