ny1
Jun 02, 2016Aspirant
Two laptops + switch: Always worked, now it doesn't
Hi, We have two laptop computers, a Mac and a PC. They both connect via Ethernet to a switch (NetGear GS105) and the switch is connected to a modem (no WiFi). For several months now, both compu...
TheEther
Jun 02, 2016Guru
Were you previously getting two IP addresses from TWC? Most ISPs will only give you one address unless you pay extra. Perhaps TWC recently discovered that they were giving you two and revoked one of them. In any case, Netgear is probably correct on this one. You need a router. Is the modem a pure modem or a modem/router?
ny1
I'm not sure. I can only assume that I had just one IP address.
