Tybotim
Apr 11, 2022Aspirant
Unable to access cable modem C6250
I cannot access C6250 AC1600 modem. Using IP address, WWW.routerlogin.net & .com open Netgear website. Nighthawk is no use. Originally set up with genie. Modem will only connect to pc not mobile devi...
- Apr 11, 2022Problem resolved. Nighthawk finally worked.
Apr 12, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
