NetRags
Oct 24, 2015Tutor
Unable to access few websites from NETGEAR Cable Gateways
Hi Team, We have facing an issue with NETGEAR Cable Gateways (C3000/C3700) We tried to block facebook using block sites featurein GUI but no effect. When contacted NETGEAR Support they told that...
TheEther
Oct 24, 2015Guru
Netgear's block sites feature works by examining the URL in a http request. But https is encrypted, so the URL cannot be examined.
You can always try using OpenDNS's parental controls directly. You just need to configure the Netgear to use their DNS servers. You can find more information about how to set it up and customize the filtering at opendns.com.
- NetRagsOct 24, 2015Tutor
Hi,
Does LPC works with C3000/C3700? As far as I heard that customer has to wait for the next firmware update for these products.
As you said "You can always try using OpenDNS's parental controls directly" can you please explain me little more in detail?
Thanks & Regards,
Rags
- TheEtherOct 24, 2015Guru
LPC support is mentioned in the C3700 manual on page 24, so it should be supported. I guess a Netgear moderator will need to provide an official statement.
The following webpages are helpful for setting up OpenDNS:
Netgear Router Configuration (Good visual instructions for setting up a Netgear router to use OpenDNS)
FamilyShield Router Configuration (This is a "set up and forget" option)
OpenDNS Support Homepage (There are lots of helpful links here)
- NetRagsOct 25, 2015Tutor
Hi,
Yes, It is mentionedin the User Manual as well as on the Box itself. But I am not able to complete the setup. When I contacted Tech Support they had mentioned with the current firmware it won't work. They are saying this for more than a year. We need to wait for the next firmware update from ISP.
Thanks,
NetRags
Hi,
ISP: Comcast
Thanks,
NetRags
