Djdamjano
Jul 16, 2024Follower
Unable to login to my CM2500 modem after activating it with my ISP
Hi there. I'm trying to login to my CM2500 modem using default password and the password stated in the hardware itself but I'm not able to. I was able to login before activating it with my ISP and d...
Jul 16, 2024Guru - Experienced User
Disconnect the ISP coax cable line from the CM modem. Then factory reset the modem. After it's semi ready, can you access it web page at 192.168.100.1 with a wired PC?
Djdamjano wrote:
Hi there.
I was able to login before activating it with my ISP and during the activation process but once it was activated, I can no longer login.
Not sure if this has anything to do with it but I do have a small 6 port switch between the modem and the hard wired device in trying with.
I can get to the login page on my devices (computer and cellphone) but unable to login.
No error is shown, just goes back to login page after entering my password.
