Spider223
Jun 04, 2017Guide
Unable to set to Internet time?
Currently using firmware version : V2.01.18 on my C6300. There is no provision to let me set the time, and apparently whoever is setting the time is an hour off from my U.S. Eastern Standard Time...
DarrenM
Jun 07, 2017Sr. NETGEAR Moderator
Hello Spider223
With cable modems that info is updated by the CMTS which is the server that tells your modem to work and give you the correct speeds and all the info the modem needs to communicate.
DarrenM
Spider223
Jun 07, 2017Guide
DarrenM
All well and good that that is how it CMTS is SUPPOSED to work, but apparently XFINITY didn't get the message .
My router works great in-so-far as modem speeds, and with nothing dropping out during transmission, so they have two out of three, and that's not bad if I'm Meatloaf singing a a song. But, I'm not Meatloaf, and two out of three is close, but no cigar.
My Netgear AC1750 (C6300) modem/router, of which Xfinity does not give customer support to, since it is MY modem, does not have the correct time. I apparently have no way to override whatever erroneous time data is being sent my way. I have owned modem\routers before, and have always had the option to set time zones, and or daylight savings time. My previous Xfinity supplied DOCSIS 3.0 Motorola modem\router also had this capability. I guess I don't quite understand Netgear's intent of dumbing down this modem\router. When I read other questions/comments in the Netgear community, it sounds as if other Netgear DOCSIS 3.0 modem\routers have the ability to correct at least Daylight Savings Time, which brings me back to the same question, why would Netgear dumb down their AC1750 (C6300) modem\router?
Since Netgear doesn't give the option to set the time on this device, why include a SCHEDULE option, since I am being left to the whims of XFINITY on what date/time I am operating in,
Makes no sense to me that Netgear would cripple this device, especially in this type of situation, where apparently my ISP is sending out the incorrect time data to everyone in the Eastern Time Zone of The United States. Is there a possibility that Netgear's firmware code for this device (C6300) is misinterpreting the time data by one bit, and toggling one hour different.
Actual time at present is 21:35, but my (C6300) is still showing 20:35
