Spider223
Jun 04, 2017Guide
Unable to set to Internet time?
Currently using firmware version : V2.01.18 on my C6300. There is no provision to let me set the time, and apparently whoever is setting the time is an hour off from my U.S. Eastern Standard Time...
DarrenM
Jun 07, 2017Sr. NETGEAR Moderator
Hello Spider223
With cable modems that info is updated by the CMTS which is the server that tells your modem to work and give you the correct speeds and all the info the modem needs to communicate.
DarrenM
Spider223
Jun 12, 2017Guide
I just received an email today from Netgear Community with the following:
"A reply to a topic you are following has been accepted as a solution!"
Not sure what the "solution" was, but there has been no solution as of yet. The modem router is still off on it's time, Xfinity says they are send time data out, my AC1750 (C6300) is off by an hour, AND my router still does not allow me to set time or time zone (firmware version V2.01.18).
If anyone else is using this modem/router, whether using Xfinity/Comcast, or anyone else, please post here if your time is correct.
Please post your ISP (Comcast, COX, WARNER, etc..), and if your time is correct,
The current time can be found in your AC1750 modem/router under ADVANCED - SECURITY - SCHEDULE.
