Spider223
Jun 04, 2017Guide
Unable to set to Internet time?
Currently using firmware version : V2.01.18 on my C6300. There is no provision to let me set the time, and apparently whoever is setting the time is an hour off from my U.S. Eastern Standard Time...
DarrenM
Jun 07, 2017Sr. NETGEAR Moderator
Hello Spider223
With cable modems that info is updated by the CMTS which is the server that tells your modem to work and give you the correct speeds and all the info the modem needs to communicate.
DarrenM
Spider223
Jun 15, 2017Guide
Page 33 of the downloadable owners manual for this router/modem says I should have this option:
4. Select ADVANCED > Security > Schedule.
5. Specify when to block keywords and services:
•Days to Block. Select the check box for each day that you want to block the keywords or select the Every Day check box, which automatically selects the check boxes for all days.
•Time of Day to Block. Select a start and end time in 24-hour format, or select All Day for 24-hour blocking.
6. Select your time zone from the menu.
7. If you live in an area that observes daylight saving time, select the Automatically adjust for daylight savings time check box.
8. Click the Apply button.
Your settings are saved.
This option is not available. At least not available on XFINITY. This still needs fixed!
