Spider223
Jun 04, 2017Guide
Unable to set to Internet time?
Currently using firmware version : V2.01.18 on my C6300. There is no provision to let me set the time, and apparently whoever is setting the time is an hour off from my U.S. Eastern Standard Time...
DarrenM
Jun 07, 2017Sr. NETGEAR Moderator
Hello Spider223
With cable modems that info is updated by the CMTS which is the server that tells your modem to work and give you the correct speeds and all the info the modem needs to communicate.
DarrenM
Spider223
Jun 18, 2017Guide
Is one tech dictionary answer all this forum gives, and then the question is dumped as answered?
Will a firmware update be forthcoming that will address this issue on the AC1750/C6300?
Any reason the options described in the users manual were taken out in the latest firmware update?
- DarrenMJun 20, 2017Sr. NETGEAR Moderator
Hello Spider223
I got a clarification on this the time is updated by the ISP and can not be changed manually the issue is the system does not use daylight savings so they do not have issues when they look at logs on there system.
DarrenM
