RamRod123's avatar
RamRod123
Follower
Dec 03, 2017
Unable to set up MOCA decives with my CM600 modem and Nighthawk router
I just installed both of these to replace my old comcast modem/router combo. Before i bought this i was told that it was MoCa enabled and compatable with my device. I just wanted to know what I am doing wrong here. Internet provider is comcast and my MoCa device is the Actiontec Single Dual-Band Wireless Network Extender and Ethernet Over Coax Adapter.
  • The CM600 is a DOCSIS modem.  It doesn't support MoCA.  MoCA can coexist with DOCSIS on the same coax cable, but you will need a second MoCA adapter.  Here is one way to set up things:
    [coax from street]+--+[PoE filter]+--+[splitter]+--+[CM600+--+[R7000]
                            [ActionTec]+-----+   +------------+[MoCA Adapter]
    Alternatively:
                            [ActionTec]+----------------------+[MoCA Adapter]
    • vkdelta's avatar
      vkdelta
      NETGEAR Employee Retired
      did you buy right kind of splitter? for MoCA splitters need to support upto 2GHz (standard splitters have cutoff at 1 GHz).
      Btw, Nice ASCII Art typing. Do you do it by hand or you have a tool to do it?
      • TheEther's avatar
        TheEther
        Guru
        I just Googled for 'ascii art tool' and used the first hit: asciiflow.com. It has the basic tools for drawing.
