CKnight90
Jun 25, 2025Tutor
Uncorrectable Errors - Tech Questions
Few months ago I had issues with games randomly disconnecting. This started to happen after a wind storm that came through the area. I noticed DS OFDM channels had Uncorrectables. So I checked all my...
CKnight90
Jun 25, 2025Tutor
Yes it's the cm1200. I'm not sure how much uptime the modem has before I restarted it a couple hours ago. But I've never seen so many uncorrectables in the downstream bonded channels. Here's a screenshot of what it shows right now. 2hrs since restart.
Jun 26, 2025Guru - Experienced User
Power levels are too high:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Please post a screen capture of the event logs page: https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
- CKnight90Jun 26, 2025Tutor
Thanks for the information! I'll check things again later today.
I did clear the logs last night when I restarted the modem. So this log is fresh.
- FURRYe38Jun 26, 2025Guru - Experienced User
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
