CKnight90
Jun 26, 2025Tutor
Uncorrectable Errors - Tech Questions
Few months ago I had issues with games randomly disconnecting. This started to happen after a wind storm that came through the area. I noticed DS OFDM channels had Uncorrectables. So I checked all my...
CKnight90
Jun 28, 2025Tutor
It was a Cox tech and he also was a contractor. Woke up today and now my modem randomly has only the Lan lights on and rest of the lights are off. Power cycling fixes the issue. I've had to power cycle it 2 times today because of it. The power readings look the same. I'm wondering if the high power signal is causing this issue? Like the modem is going into protection mode when the power levels get too high? I did call Cox last night about the tech taking the filter but all the rep could do is submit a request to bring it back. I called them today and was told I will need a tech to come out again to address the modem having this issue. I told them it's most likely caused by the tech taking the filter when a previous tech said it was needed. I factory reset the modem to see if that helps. The Tech support rep tried to refer me to Netgear customer service. I said "The power levels are out of spec and the issue is not having the filter." She then said "I could contact them and see if there's an update needed for the modem or I could do it myself." I told her there's no option in the modem settings to do so. She said "The Genie has that option." I told her it's not there and it was there before when I first got the modem, and I updated it, but the option went away. She said "Well we can do it on our end because it's not our equipment." I used to work at cox tier 1 tech support and we were able to before, I guess they got rid of that option? I once again forgot to take a screenshot of the logs. I will for sure again. I'm worried if my modem is dying or if it's not that? I do have an old CM1000v2 I could swap in, but rather be sure this fairly new CM1200 is bad or not. I'm greatfull of your feedback and all this random things happening! Here's once again my readings...
| Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Downstream OFDM Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Upstream OFDMA Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Extended Upstream Transmit Power | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Enable Extended Upstream Transmit Power |
Kitsap
Jun 29, 2025Master
The CM1200 does not now, nor has it ever had the option for the end user to update the firmware. It is the same as the other CM series modems. ISP firmware updates only.
In your current set of readings, Your power levels are still high, and I note you no longer have a second upstream OFDMA channel locked at 918 MHz. In your other posts, you had that second channel locked.
We may have a terminology issue. I use a 3 dB attenuator to lower my power levels. It has no filtering. You are calling yours a filter. Sometimes it is called an attenuator pad.
This brand of attenuator comes in 3 dB and 8 dB sizes for around $5. Links to Amazon.
