Khair
Aug 11, 2016Follower
Unrecognised device in home network
When I look at the network map using the Genie application I see a device with ip address 192.168.0.5; I don't know where that is coming from as all the other devices are accounted for. Also, I note ...
dorald
Sep 02, 2016Tutor
I'm in the same situation. Only difference is that I have several devices connected to my home system that I either can't find nor explain. One apprears to be from Japan???
When I click on them, the "BLOCK" option is not there. Should I reboot, change PW, what? How did they get there in the first place? Did they get lucky guess my PW? Am I in any danger of these connections getting my confidential information?
DarrenM
Sep 06, 2016Sr. NETGEAR Moderator
Hello Dorald
If you are sure they are not something in your home that you connected then I would suggest you change the PW and reset the modem and check if they show up after your connect your devices again.
DarrenM
- Mav4GOct 27, 2016Aspirant
The question asked was: Why can you block only some of the devices? I have an unknown device on my network I am not allowed to block. Why is that? And how do I override it? Otherwise NETGEAR equipment is useless to me...
