donawalt
Mar 02, 2024Mentor - Experienced User
Update on CM2050V firmware?
Hi, is there any update to the CM2050V firmware that will re-enable the mid-split higher upload speeds? The latest firmware was pulled in October maybe? Any update to this thread's status reporting?
Nothing yet. We don't get that info from NG.
The CM2050V is being worked on is all I can say.
How's your CM3000 doing? Been enjoying mine. đ
- donawaltMentor - Experienced User
It's working good! It's been up just about 1 day now. The web interface is identical to the CM2000 and CM2050 as far as data reported. Power levels and SNR consistent with those models. no correctible or uncorrectable errors yet, so no issues on the mid-split network so far. I got one T3 error yesterday, I only noticed it through the log though. Speeds are great.
Good to hear.
There a speed test capture you could post?
