oldglory1776
Nov 16, 2020Tutor
Upgrading Internet Speed, Reliability, and Connectivity
Hi all, I am loking for input and adivce on how best to upgrade my internet speed, realiability, and connectivity.
My current set-up is Internet Service: (300 Mbps Cox Internet (Scottsdale, AZ) -> Modem: ARRIS SURFboard 16 x 4 DOCSIS 3.0 Cable Modem (Model No. SB6183) -> Router: Linksys - Velop AC2200 Tri-Band Mesh Wi-Fi 5 System (Model No. WHW03). My most recent Broadband Spped Tests have been yielding 60 mbps download speeds and 23 mbps uplaod speeds in my office, which is where I spend the majority of my time connected to the internet.
I am thinking of going to one to the following set-ups, welcome to any and all thoughts.....
Idea A (Total Cost ~$660):
Internet Service: Cox Gigablast (Scottsdale, AZ) (940 bmps download / 35 mbps upload)
Modem/Router: NETGEAR - Nighthawk Dual-Band AX6000 Wi-Fi 6 Router with 32 x 8 DOCIS 3.1 Cable Modem (Model No. CAX80-100NAS) & NETGEAR - Nighthawk AX1800 Dual-Band Mesh Wi-Fi 6 System (Model No. MK62-100NAS)
Idea B (Total Cost ~$1,250)
Modem: NETGEAR - Nighthawk 32 x 8 DOCIS 3.1 Cable Modem (Model No. CM2000-100NAS)
Router: NETGEAR - Orbi AX6000 Tri-Band Mesh WiFi System (Model No. RBK853-100NAS)
Idea C (Total Cost ~$1,200)
Modem: NETGEAR - Nighthawk 32 x 8 DOCIS 3.1 Cable Modem (Model No. CM1200-100NAS)
I know these are relatively expensive set-ups but with how much we are using the internet, it is something we are willing to invest. Any and all thoughts are welcome!
How big is your home?
What's it made of for the interior walls? Certain materials block wifi very well.
Reason I ask is the WHW0303 is a pretty solid mesh system in terms of performance. Its actually ranked #2 in terms of AC mesh systems.
https://www.smallnetbuilder.com/tools/rankers/wifi-system/view
It should have no issue handling 300mbps. (you won't hit that speed if you're connected to 2.4ghz because its slower) You do get some drop off of speed with moving from node to node but its a solid performer.
I'd be a bit curious why you aren't able to max out your speeds before investing in a new system. reason why is if its a line issue from cox, it'd be pointless to upgrade. Or if its a home structure issue, the $ might be better invested in having someone hardwire in a few ethernet jacks around the home. Or moca adapters.
Again, it'd be better to find out what the actual bottlenecks in the system are before dropping a grand on a new system.
- Thank you plemans!
The home is 3,200 square feet. It has 1/2 inch thick drywall interior walls.
How else would you recommend troubleshooting, should I pay to have Cox come out and test the line?
Your advice is greatly appreciated.plemans One other thing to share. My speed tests standing next to the modem/router is running 280 mbps+ download speeds.
When I run the test anywhere downstairs (my modem/router is upstairs) the tests are coming back in the 45-55 mbps range. It may have something to do the flooring/ceiling or the two routers downstairs are not functioning correctly with the mesh system.
Thoughts?
