oldglory1776
Nov 16, 2020Tutor
Upgrading Internet Speed, Reliability, and Connectivity
Hi all, I am loking for input and adivce on how best to upgrade my internet speed, realiability, and connectivity. My current set-up is Internet Service: (300 Mbps Cox Internet (Scottsdale, AZ) ...
Nov 17, 2020Guru - Experienced User
The 3200sqft is about perfect for your setup. I have a similar sized home and structure and used to run a route plus 2 satellites for indoors and it covered fine.
Here's how I'd start troubleshooting.
1. hardwired directly into the modem with a pc/laptop. Ensure you get full speed at the mode.
2. Then test the router and each satellite hardwired in with the pc/laptop. You want to make sure the router is getting full speeds from the modem. And then you want to ensure proper placement of the satellites. They can be to close together. Netgear usually recommends a minimum of 30 feet from router---satellite to ensure devices roam properly. write down what speeds you're getting.
If you're getting full speed from the router and then decent speeds from the satellites hardwired in, then it'd be time to start troubleshooting the wireless on the satellites. Since you say the router gets full speed when close to it. You might check with linksys and/or their forums for specific settings with the velop. I've never used it but I have used several other mesh systems and many times optimizing can make significant differences.
If you don't get decent speeds hardwired in, then I'd investigate placement of the satellites as well as again, check with linksys forum/support.
That system should be able to function quite well. I'm not pushing you away from netgear but it should be a pretty solid setup you have for what your speeds. once you hit gigabit, then an upgrade to AX would be beneficial (if you have AX devices).
and again, maybe you want to investigate hardwiring in the satellites. I know in my home, all my phone lines were ran with cat5e line and I was able to switch all the jacks to RJ45 and have a switch in my utility room. so for roughly $50 (diy) i was able to hardwire in many devices and all my satellites. It significantly improved performance in my home.
oldglory1776
Nov 17, 2020Tutor
Thank you plemans. I am working through the troubleshooting you outlined, and am waiting on hold with Linksys tech support as we speak. Thank you again.
I am going to switch to the Cox Gigablast Service, with the current promotion it is actually cheaper than what I am paying now for the 300 mbps service. Which means I need to upgrade my modem - any suggestions?
- plemansNov 17, 2020Guru - Experienced User
I wouldn't go with CAX80. I have it and love it on xfinity. But when we find people with issues on here for the CAX80, its tending to be people who are Cox service.
So I'd go with a standalone modem like the CM1000, CM1100, or CM2000. (provided they're compatible, check with cox just to confirm)
I also wouldn't recommend the CM1200. it has extra ports but on cox, they're pointless as you can't use port 3/4 unless you have a business class line or pay for extra ip address. And port 2 only works if using wan port aggregation or again pay for extra IP addresses.
