RajaDaja's avatar
RajaDaja
Luminary
Feb 26, 2025
Upload indicator iight very dim
Provider is Xfinity, speed tier is 2 gigs down, 300 mb up. I’m getting these speeds, All the indicator icons on the modem are nice and bright except the upload indicator light. I remember it being luminous as the others but now it’s very dim. Could this indicate a problem? Thanks
  • If you're not having any issues, I wouldn't worry about it. Most people rarely see them anyway as the modem should be pretty set and forget.
      • FURRYe38's avatar
        Have you powered OFF the modem for 1 minute then back ON?
        Seen other posts about the CM2000 having similar issues. No issues with the ISP service.
