byteme67
Apr 25, 2019Tutor
Upstream light flashing no internet connection
I was trying to log into my router tonight and for some reason it didn’t like the password I was entering. I got to the security questions page and it didn’t like those answers either. I know the answ...
byteme67
Apr 25, 2019Tutor
Let me rephrase this. Everything was working great until I reset the unit using the reset switch on the back. Now I have no internet connection.
Yes I can log into the web management. And nothing in the user manual states check out this or that when your upstream light is flashing green and the power, the downstream, the 2.4Ghz, the 5Ghz and the Ethernet lights are solid green. And your internet light is out.
I’ve checked all cabling. Nothing changed there. I did reseat the coax just in case because in the web management it states there is no RF signal.
This is frustrating
This is frustrating
additude
Apr 26, 2019Virtuoso
Can you connect it to the cable jack in your home that your Cable Box is connected to and see if you can get a signal there.
Use the cable that connects to your cable box.
If you don't have that availability, then try to use a cable jack that is closest to where cable comes into your home. If you don't know that then you need to verify that you have a "Cable Signal" at the jack that you are using. But you have to verify that you have a valid cable signal at the jack that you are plugged into. Don't assume. Prove.
Make sure that your Modem/Router is NOT located in a place where it can get too hot and overheat.
If that doesn't work:
Maybe you can use your phone as a HotSpot to get your computer on the internet to download firmware.
Download a firmware version that you want from NetGear Support and store it locally.
I would download both the current version that you have installed and also the latest version.
Then reset the modem via the button on the back. Hold for a slow count of 10 then release.
Update the firmware via the local file you downloaded.
Try Latest version first.
Reboot and see if that helps.
If that doesn't help, then maybe you can return it, exchange it, contact support for options.
