JerradP
Sep 19, 2022Aspirant
Upstream Solid Orange Light - 16x4 DOCSIS 3.0 Cable Modem (CM500)
My modem has recently changed to where my Upstream LED indicator is a solid orange color. I've talked to my ISP (Xfinity) and they said everything on their end (power, connection) looks fine and it's...
JerradP
Sep 19, 2022Guru - Experienced User
You have lots of criticals that the ISP needs to review and help resolve.
- JerradPSep 19, 2022Aspirant
They said they can send a tech out, but if the issue isn't with Xfinity I'll be charged $100. In your opinion is this an issue on their end, meaning I should schedule the appointment? It's a big risk.
- FURRYe38Sep 19, 2022Guru - Experienced User
The line up to the modem needs to be checked by you or someone as suggested in earlier posts. Kinks and fittings and Splitters can cause the correctables and un-correctables to be seen here.
Try the modem at a firends, nieghors or families place to see if the problem follows, if not, then the issue is with the lines up to the modem and ISP responsbility.
- plemansSep 20, 2022Guru - Experienced User
Xfinity is responsible for the wiring up to the home. So your best option is to move the modem to right where the coax comes into the home. This limits the potential issues that could be inside the home causing the issues. If its directly connected to that wire with no splitters/amplifiers/anything else and is still having those issues/errors, then its on the isp to check them. And if it doesn't have the issues, then you know its the wiring in the home that is the issue.
