Knatt94's avatar
Knatt94
Follower
Sep 26, 2020
USB antenna
Do they have usb antenna to increase the range of my WiFi? If so which are the best recommendations?
  • No. I would recommend getting into a wifi mesh system, like a NGs Nighthawk mesh system or Orbi mesh. There is a Orbi 1 series that you could connect up to your modem.
1 Reply
  • FURRYe38's avatar
