EKMerwick
Jan 21, 2017Aspirant
USB Compatible devices for the C6300
Will a WD 2 TB Elements Portable External HD, USB 3.0, Model # WDBU6Y0020BBK-EESN work with the Netgear AC1750 WiFi Cable Modem router Model # C6300?
- DarrenMSr. NETGEAR Moderator
Hello EKMerwick
You may want to check out this KB
https://kb.netgear.com/18985/ReadySHARE-USB-Drives-Compatibility-List?cid=wmt_netgear_organic
DarrenM
- EKMerwickAspirantThank you for the link. I have seen that link and went forward from there. The one part number I posted is slightly different than the one on the link. I was seeking an answew specifically to that model number.
