JustAsIAm's avatar
JustAsIAm
USB Storage | Create Network Folder
I have a new C3700 router and it is working fine, except the following:
I select Advanced | USB Storage | Basic Settings and my 1TB hard drive shows up just fine, but when I go to "Advanced Settings" and select the radio button next to my hard drive, then select either "Edit" or "Create Network Folder", it goes back to the default "Advanced Settings" page.
Ideas?
1 Reply
  • Make sure Pop-up blocker is disabled or pop-up is allowed. There should be a small window that will appear.
