Eric_'s avatar
Eric_
USB Storage Folder Edit Password
Netgear Genie-Advanced-WPS Wizard-USB Storage-Advanced Settings-Available Network Folders
Connected a USB 2.0 flash drive to the router and it is networking (readyshare) just fine, my issue is trying to set a Read & Write Access password, after clicking the Folder in "Available Network Folders" and then Edit button, the page only refreshes, it doesn't open the edit window to set a password. How can I set the password?
  • Hello Eric
    Do you have a pop up blocker because it is a pop up window that comes up when you hit edit. also try to use a different browser.
    DarrenM
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Hello Eric
      DarrenM
      • Eric_'s avatar
        Eric_
        Yep, that was the fix, thank you for the assistance.
