mark45865's avatar
mark45865
Follower
Nov 08, 2023
Used CM1150v no mac address
I bought a used 1150v from ebay, no bottom mount, and the only thing listed in the modem is the serial number... no mac address anywhere on any screen...
1 Reply
    Log in to the user interface.  Go to the Advanced Tab.
    Select Administration -> Modem Status and a small window will open on the right.  That window has a scroll bar.  The MAC address is the last item at the bottom of the scroll.  It is labeled CM MAC.
