spon
Apr 28, 2018Aspirant
Using a Netgear 4G modem with Netgear D6400 router
Hi,
I'm looking to purchase a Netgear 4G modem (NETGEAR LB2120-100UKS) to use as a back-up internet connection with an existing Netgear D6400. The D6400 is used for fibre connection in the UK. The ...
antinode
Apr 28, 2018Guru
> [...] The existing router has an onboard modem and it's not clear
> how/if this would need to be disabled if the unit was working with the
> 4G modem. [...]
A better way to look at the question might be to ask how the router
decides between the DSL modem and the Ethernet WAN/Internet port. In
the D6400 User Manual, there's a section, "Change the Physical WAN
Connection Preference" which says:
The modem router can autodetect the type of WAN connection.
However, you can also set the WAN connection preference manually
to either the DSL port or the Ethernet WAN port.
I don't know what "autodetect" actually means, so I would not bet
that the router would automatically switch between the two WAN
connections when the (fiber) DSL link dies and re-awakens. I haven't
tried it on my D7000, so I know nothing, but my guess would be that an
Ethernet connection would be preferred over a DSL connection. (But what
do I know?)
I suspect that you could use the D6400 either way, but you might need
to switch it manually between the two WAN interface choices (ADVANCED >
Setup > WAN Setup : WAN Preference). I haven't looked, but I'd also
guess that there are more sophisticated (industrial-grade) routers which
can be configured to do what you want (automatically).
- sponApr 29, 2018AspirantThanks for the helpful reply. I'm not so worried about auto failover as this is more a contingency if the main fibre falls over. I've purchased a Netgear 4G modem which looks like it should work but I'll know more when Amazon deliver tomorrow. I did ask for help from Netgear presale support but seems that new order enquiries aren't a priority as no response :(
Fingers crossed and thanks for your advice.
spon
