tcaron3097
Feb 26, 2016Follower
Using a range extender with AC1750 WiFi DOCSIS 3.0 Cable Modem Router
I am using a Netgear WN2000RPTv2 range extender with my current Netgear router. I have purchased the replacement modem/router model mentioned in the subject line. I noticed on Amazon comments that a perceived plus for the AC1750 was the fact that it has dual band, whereas the commenter’s older cable modem required 2.4Ghz “because we had too many devices that didn’t do 5”.
My question: My range extender seems to feature that it is designed to support 2.4Ghz. Will I need to constrain all wireless connections in order to continue using this range extender, when I drop in the new modem/router I bought from Amazon?
Thank you
1 Reply
Your range extender will extend only 2.4 GHz Wi-Fi. It will not be able to assist any devices that use 5 GHz. Those devices will either need to connect directly to your new modem/router, or you will need to constrain them to 2.4 GHz, or you can buy a dual-band extender. But read on before deciding.
Consider this. While 5 GHz signals degrade much faster than 2.4 GHz as distances increases, it is often able to maintain much higher speeds due to wider channels (typically 40 MHz and 80 MHz vs 20 MHz that typically achievable at 2.4 GHz) and superior protocols (i.e. 802.11ac, though your devices must also support it). Your 5 GHz-capable devices may do just fine without the assistance of a range extender. Your results will depend very much on the layout, size and construction materials of your residence.
Try out your new modem/router. If well placed, it may be powerful enough on its own to reach most parts of your place. Then you can tactically place your extender to provide coverage to one or more dead spots. If you give both the 2.4 GHz and 5 GHz networks the same name, then your dual-band devices can dynamically pick the best frequency to operate at.
