rumblefish
Nov 11, 2017Aspirant
Using a switch on before a 2nd Router
My internet line in my den come in to netgear router 1 (Netgear R6300). Those Ethernet cables go out from there to: PC #1 PC #2 cat 6 cable running into Net gear Router # 2(Net Gear Night Hawk A...
antinode
Nov 11, 2017Guru
> 3. cat 6 cable running into Net gear Router # 2(Net Gear Night Hawk AZ
> 1750) in my living room.
"AZ 1750" ("AC1750"?) is a speed, not a model number. Ever
helpful, Netgear product packaging emphasizes speeds like "ACxxxx", but
that's not the model identifier.
> [...] Apple TV won't pick up my itunes library and I believe it's
> because it's not on the same router. [...]
Where is "my itunes library"? How would it know where to find "my
itunes library"?
> f I put a switch on the cat 6 line before it went into router #2, then
> would everything on the switch be considered to be part of router #1?
Not "part of router #1", but on the LAN of router #1. I don't know
enough about how an Apple TV finds an iTunes library to say whether that
would matter. I'd expect a device on the LAN of router #1 to be
visible to a device on the LAN of router #2 (but not the other way
around, unless a suitable static route were added on router #1).
> If I put a switch on the cat 6 line before it went into router #2,
> then would everything on the switch be considered to be part of router
> #1?
Part of router #1's LAN, yes. If you want the wireless capability of
router #2, then it might be simpler to configure router #2 as a wireless
access point. That would make everything part of router #1's LAN
(without adding more hardware). I'm not sure what that would do to the
more exotic features of router #2 (ReadySHARE, for example).
> Would something like NETGEAR GS105NA 5-Port Gigabit Ethernet Network
> Switch do the trick?
Sure, but if you've see one cheap-Chinese gigabit Ethernet switch,
you've pretty much seen them all.
> Does using a switch slow down my Ethernet line?
It would add a tiny bit of latency, probably unnoticable.
Visit http://netgear.com/support , put in the model number of router
#2, and look for Documentation. In the User Manual, look for "Wireless
Access Point". Or, perhaps, in the web interface: ADVANCED > Advanced
Setup > Wireless AP
rumblefish
Nov 12, 2017Aspirant
thanks for the info. i am check into the wireless access point. I like the sound of that concept.
