rumblefish
Nov 11, 2017Aspirant
Using a switch on before a 2nd Router
My internet line in my den come in to netgear router 1 (Netgear R6300). Those Ethernet cables go out from there to: PC #1 PC #2 cat 6 cable running into Net gear Router # 2(Net Gear Night Hawk A...
rumblefish
Nov 12, 2017Aspirant
Thanks Antinode. That did the trick. I set up router #2 as WAP and now my apple tv sees my library on pc#1.
Besides the readyshare, did i loose anything by makin the router number #2?
with regards to to wifi, is router number 2 just a continuaion of my wifi setting from router 1? ie if i change my wifi name, router 2 will pick it up.
appreciate the help! THanks.
antinode
Nov 12, 2017Guru
> [...] That did the trick.
What could go wrong?
> number #2?
I don't know that you _did_ lose ReadySHARE on the wireless access
point. It might still work, for all I know. (With my (very) limited
experience, and a flock of complaints which I've read here, I wouldn't
trust my valuable data to a scheme which seems to be so poorly tested
and, hence, unreliable.)
Features which are part of the router functionality are lost when you
stop using the router function of router #2, and make it a WAP. For
example, the DHCP server, port forwarding, parental controls, static
routes, and so on. In essence, a WAP acts as a simple network switch,
with just enough extra complexity to handle wireless connections.
> pick it up.
No. The wireless credentials (SSID, passphrase) on the WAP can be
the same or different. You're on the same LAN as the main router, but
how you get connected to it can be different.
One thing which you might want to do would be to reserve an address
on router #1 for (the WAN interface of) the WAP (router #2). Perhaps:
ADVANCED > Setup > LAN Setup : Address Reservation. That should make it
easier to find/access the management web interface on the WAP (which now
will _not_ be at 192.168.x.1, because that's where router #1 is).
You'll need the MAC address of router#2 for that, but it should be the
one on the label (or on the BASIC > Internet page). Something like,
say, 192.168.x.100 or .200 might be memorable.
- rumblefishNov 14, 2017Aspirant
follow up quesion,
I tried to change the wifi names on router number two. just like i did when i designated it to be a WAP, i plugged it into my power near my pc and connected my internet into router number two then to my pc. unfortunately i could not log on.
is logging in to router #2 different now that its set up as a WAP??
Much Thanks,- antinodeNov 14, 2017Guru
> [...] i plugged it into my power near my pc and connected my internet
> into router number two [...]
You don't need an Internet connection to configure one of these
devices. And removing router #1 from the situation is likely to do more
harm than good.
> [...] then to my pc. unfortunately i could not log on.
"I could not" is not a useful problem description. It does not say
what you did. It does not say what happened when you did it. As usual,
showing actual actions with their actual results (error messages, ...)
can be more helpful than vague descriptions or interpretations.
It probably has a different IP address. Now that it's on the same
LAN as router #1, it certainly can't have the same IP address as router
#1 has. As I explained before:
In the mean time, you may be able to find its address from an
Attached Devices report on router #1. After you put the equipment
connections back to a working configuration, that is.
