brnadonM
Nov 18, 2020Aspirant
Using AC1200 C6220 as an Access Point
Hello,
I was wondering if it was possible to use this modem/router as an access point for another modem?
I was trying to mess around in the settings but I was having trouble finding an option for this.
Is it possible?
Thank you,
Brandon
Hello,
I followed this tutorial: https://community.netgear.com/t5/x/x/m-p/1463500 from antinode here.
Then
I fixed my issue by giving my Computer A a new MAC address.
Thanks
> [...] I was having trouble finding an option for this.
I wouldn't expect to find one, but that may not be fatal. See, for
example:https://community.netgear.com/t5/x/x/m-p/1463500
That's written for a Netgear C6300-as-WAP, but the steps are about the
same for any other router (any make/model) which lacks a one-step WAP
option. (Especially similar for another Netgear Cxxxx.)> Model: A6200|802.11ac Dual Band WiFi USB Adapter
Nothing to do with anything?
- brnadonMAspirant
Hey sir, now my IPv4 Address of the PC connected directly to the C6220 is the same as the external ip address. I cannot connect to 192.168.0.250 from my PC connected directly to the C6220. I can't connect to 192.168.0.1 either.
But when I connect my laptop to the C6220 (working as an access point) through wifi, I can access both of these. It works with ethernet too. What's wrong with my computer?
Thank you> Hey sir, now [...]
What did you do? What, exactly, did you connect to what, exactly?
> access point for another modem? [...]What is your "another modem"? If it's really a _modem_, and does not
include a router, then I'd expect problems. If you expect to connect
multiple client devices to your ISP, then you need a (NAT) router of
some kind, not only a WAP. And, as a general-purpose router, a model
Cxxxx is useless; it has no Ethernet WAN/Internet port.> [...] What's wrong with my computer?
I'd guess nothing, other than to what you connected it.
