txjon's avatar
txjon
Using C3700 as a Modem Only
Hello,
I have a C3700 Cable Modem Router but have decided to purchase a new router.  Is there any reason I shouldn't just put the C3700 in modem only (bridge) mode versus buying a new modem?  (Which would probably be the Netgear CM500)
The thing that has me concerned that perhaps I shouldn't use my C3700 in modem only/bridge mode is an article on Netgear support titled "How to set the cable modem/router to be on modem only."  https://kb.netgear.com/27191/How-to-set-the-cable-modem-router-to-be-on-modem-only
The article shows how to set up modem only mode but then says "Netgear does not recommend setting your cable modem/router to modem only.  This mode should be used under special circumstances only."
Why does the article say this?  Are there any advantage to my buying a new cable modem vs putting the C3700 in bridge mode? (Or from the other perspective are there any disadvantages to using the C3700 in bridge mode vs buying a new modem?) Does the C3700 in modem only/ bridge mode function any differently than a straight cable modem would?
Thanks for the help.
  • Re: Using C3700 as a Modem Only
    I have Spectrum, formerly Time Warner Cable, and I have a 60 MBPS internet only plan.  If the C3700 will function in 'modem only' mode as well as a standalone modem then why does the Netgear article I quoted say "Netgear does not recommend setting your cable modem/router to modem only?"
    >> It is not recommended unless you have another router.
    You will have to connect Router behind C3700 In bridge mode and you can connect ONLY a single device behind C3700 in Bridge mode.
    Also I do still want to know if the C3700 in modem only/bridge mode operates the same way as a stand alone modem?  For example I read somewhere that in bridge mode modem routers will obtain IP addresses from the ISP directly.  Is that the case with the a standalone modem too?
    >> every device connected to the ISP network will pull an IP from ISP.
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    what speed tier are you on? who is your ISP?
    you should be able to just turn the C3700 to save money on buying new modem and just C3700 as Modem-only with your new router.
    • txjon's avatar
      txjon
      Thank you for the additional information.
      • vkdelta's avatar
        vkdelta
