SantaFean13
Nov 23, 2025Tutor
Using Nighthawk web app to turn off wireless radios
I'm trying to turn off the wireless radios on my CAX80 using the Nighthawk web app. The support chat system says I should go to Advanced > Setup > Wireless Setup and then "Uncheck the Enable Wireles...
Nov 23, 2025Guru - Experienced User
You have to do that from the gateways WEB UI in a web browser.
Or press the wifi radio button in front of the gateway for 5 seconds then release.
- SantaFean13Nov 23, 2025Tutor
Thank you. I am using the WEB UI in a web browser. Where do I find the check boxes to disable the radio?
