SantaFean13
Nov 23, 2025Tutor
Using Nighthawk web app to turn off wireless radios
I'm trying to turn off the wireless radios on my CAX80 using the Nighthawk web app. The support chat system says I should go to Advanced > Setup > Wireless Setup and then "Uncheck the Enable Wireles...
CrimpOn
Nov 23, 2025Guru - Experienced User
page 55 of the User Manual
https://www.downloads.netgear.com/files/GDC/CAX80/CAX80_UM_EN.pdf
SantaFean13
Nov 24, 2025Tutor
Thank you and understood. But my point is that when I go to Advanced > Setup > Wireless Setup in my Web UI, there are no check boxes for "Enable Wireless Router Radio".
- FURRYe38Nov 24, 2025Guru - Experienced User
How about on the Basic tab/Wireless setting page?
- SantaFean13Nov 24, 2025Tutor
Thanks for the question. There is no "Enable Wireless Router Radio" check box on the Basic > Wireless page either.
Please capture the screen page of the Advanced > Setup > Wireless Setup and post it here please.
Does the front WiFi radio button work to disable the wifi radios?
