Seeking2018
Jan 16, 2018Tutor
Very Frustrated with Speed of New Modem
Comcast recently had an update to their internet speed. With my old modem, the computer attached via ethernet was 125 mbps; the problem was my wifi computer was less than 10. So I bought this route...
michaelkenward
Jan 17, 2018Guru - Experienced User
The R6900 mentioned in your footer is a router. What modem are you using?
Seeking2018
Jan 17, 2018Tutor
c7100v I believe is what it's called.
- michaelkenwardJan 17, 2018Guru - Experienced User
The C7100V is a modem/router. While it doesn't explain the slow wifi, you now have two routers on your network. You need to stop them arguing among themselves over control of your network.
There is a manual for the C7100V somewhere at the end of this link:
>>>> C7100V | Product | Support | NETGEAR <<<<
If you read page 107 of the manual you will see how to set up the modem router in bridge mode.
You should also read the Quick Start to help in setting up your network.
When you have sorted that out you may find it easier to restore sanity to your system.
- Seeking2018Jan 17, 2018Tutor
I have been reading the quick start. I did find the users manual and I scrolled to page 107, I don't see a remote access under set up. I'll keep messing around. Again, not sure why the person I spoke with didn't set this up correctly. For me, this is getting to be way too much of a hassle and will probably return it and go with something easier.
Seeking2018 wrote:
...I scrolled to page 107, I don't see a remote access under set up.
Where did "remote access" come from?
Page 107 tells you how to turn off the modem's router operation so that your R6900 can work as your network's router.
Remote access is something completely different.
For me, this is getting to be way too much of a hassle and will probably return it and go with something easier.I don't know which bit you plan to return, the R6900 or the C7100V, but whatever you get to replace it will leave you with the same challenge for setting it up.
There is also support stuff for the R6900 at the end of this link:
>>> R6900 | Product | Support | NETGEAR <<<
It comes with its own Quick Start guide. You could turn the R6900 into an access point, but that is probably getting too complicated.
