Seeking2018
Jan 16, 2018Tutor
Very Frustrated with Speed of New Modem
Comcast recently had an update to their internet speed. With my old modem, the computer attached via ethernet was 125 mbps; the problem was my wifi computer was less than 10. So I bought this route...
Seeking2018
Jan 17, 2018Tutor
I have been reading the quick start. I did find the users manual and I scrolled to page 107, I don't see a remote access under set up. I'll keep messing around. Again, not sure why the person I spoke with didn't set this up correctly. For me, this is getting to be way too much of a hassle and will probably return it and go with something easier.
michaelkenward
Jan 17, 2018Guru - Experienced User
Seeking2018 wrote:
...I scrolled to page 107, I don't see a remote access under set up.
Where did "remote access" come from?
Page 107 tells you how to turn off the modem's router operation so that your R6900 can work as your network's router.
Remote access is something completely different.
I don't know which bit you plan to return, the R6900 or the C7100V, but whatever you get to replace it will leave you with the same challenge for setting it up.
There is also support stuff for the R6900 at the end of this link:
>>> R6900 | Product | Support | NETGEAR <<<
It comes with its own Quick Start guide. You could turn the R6900 into an access point, but that is probably getting too complicated.
- Seeking2018Jan 17, 2018Tutor
That is so strange!! I clicked on the link you supplied, I had to sign into netgear, when I did I found online manual, went to page 107, found about remote router. So maybe I have a different box? I don't know. I've been trying to call them and see if I can get help that way. It makes sense what you say.
- michaelkenwardJan 17, 2018Guru - Experienced User
Page 107 in the document I mentioned has a section:
Set Up the Modem Router in Bridge Mode
AC1900 Cable Modem Voice Router Model C7100V User Manual - C7100V_UM_EN.pdf
You can find the Model Number for your device on the label. Something like this:
It is probably on the bottom of the thing.
I must have selected the wrong thing b/c what I have is rectangular box w/o any antenas.
I just spent 40 mins on the phone w/ tech support and it seems to be working now. Thanks for trying to help me out!!
