agarg1
Dec 01, 2015Aspirant
Very Slow (almost zero) Internet Connectivity - Netgear C3700 TWC - Austin, TX
Hi, I have a new C3700 Netgear Cable Modem Router with TWC Extreme Internet here in Austin, TX (78717) and everything worked great for about 2 months. However, now I am not able to access Intern...
agarg1
Dec 05, 2015Aspirant
I have some new insight to share. I enabled the guest network option on the Netgear router setup page, connected to the guest network wirelessly and everything started working fine. Got download speeds of 50mbps.
So the guest network works but the actual secured wireless network doesn't. Any suggestions what might be causing that?
Thank you.
DarrenM
Dec 10, 2015Sr. NETGEAR Moderator
Hello agarg1
Have you tried to clear the saved wireless networks from your device and then reconnect to the router see if that works. You could also try changing the SSID and password on the router check if anything changes there if that does not work I would suggest to do a factory reset and try again. Hope to hear your feedback.
DarrenM
