Hapa
Nov 09, 2020Aspirant
Very Slow CM500 connection speed
Brand new Netgear CM500 16x4 modem, Linksys AC1000 dual band wifi 5 router, and 600mbps Xfinity plan.
I am only getting about 30mbps DL speed and about 10mbps upload speed.
Xfinity says they are seeing full speed entering my address and that it must be an issue with the modem. Does anyone have troubleshooting steps or see an issue with this combination?
Thanks.
Thanks.
Do you have a screen snip of the cable connections page and the modem logs?
That's helps check your signal.When you're speedtesting, are you directly connected to the modem? That's the first thing I'd try. That ensures the router isn't causing the slowdown.
Something to also keep in mind, xifnity only rates the CM500 for up to 372mpbs. so its a bit pointless to be paying for 600mbps if you're modem can't get those speeds with the way xfinity provisions. A cheaper plan or upgrading the modem might be worth looking into.
- HapaAspirantThanks for the response. I just speed tested with direct connection to modem and got about 400mbps but connected to wifi I get about 25mbps. Does this confirm that the router is what is causing the slow speeds? That's an enormous difference. This Linksys AC1000 is supposedly able to handle 1000mbps.
it means the modem's putting out full speed. Its related to the router.
Which router is it? (hint, AC1000 is a speed, not a model)
might want to start with the linksys support site.
https://www.linksys.com/us/support/
