cllinusa
May 14, 2016Tutor
VPN Setup on Netgear Router - HELP
I would like to setup a VPN connection through PIA on my Netgear router (Model listed as C7000-100NAS), but I think it's the same or a version of the AC1900 Netgear Nighthawk. All the documents I see...
MacVille
Aug 03, 2016Initiate
I've the same problem,and the same problem of everyone else, this was my last time with negtgeat, Never Never again
DarrenM
Aug 05, 2016Sr. NETGEAR Moderator
Hello MacVille
There is no VPN settings on the cable modem.
DarrenM
- PL660Sep 21, 2016Initiate
DarrenM wrote:Hello MacVille
DarrenM
You claim on your website:http://kb.netgear.com/app/answers/detail/a_id/29322/~/c7000-product-faqs
So, is it or not?
- jeremywOct 28, 2016Initiate
As pointed out by another person here it says you do on your FAQ.
Why do I not have this option? I own a C7000-100NAS modem/router.- DarrenMOct 28, 2016Sr. NETGEAR Moderator
Hello everyone
VPN Passthrough is a feature of routers which allows computers on a private network to establish outbound VPNs unhindered. VPN passthrough has nothing to do with inbound VPNs, only outbound ones. The term comes from allowing the VPN traffic to “passthrough” the router. NO ports need opening to enable VPN passthrough, it will automatically work.
So the C7000 does not have specific settings to set up a VPN.
DarrenM
- DevilsbaneNov 07, 2016Tutor
Why is there no option? Is it just something that physically can't be done or was it just never set up? Just wondering if an update would ever come to allow this because it does seem to be a pretty commonly requested feature and it is available on the other netgear ac routers. Quite unfortunate it wouldn't be on this one too.
