cllinusa
May 14, 2016Tutor
VPN Setup on Netgear Router - HELP
I would like to setup a VPN connection through PIA on my Netgear router (Model listed as C7000-100NAS), but I think it's the same or a version of the AC1900 Netgear Nighthawk. All the documents I see...
Trickey
Aug 19, 2016Aspirant
Ive got a D7000 or ac1900 and was looking for the vpn setup if you type http://www.routerlogin.net it will let you login and change to advance to setup vpn.
hope this helps
cllinusa
Sep 21, 2016Tutor
No VPN, even under advanced setup!
