cllinusa
May 14, 2016Tutor
VPN Setup on Netgear Router - HELP
I would like to setup a VPN connection through PIA on my Netgear router (Model listed as C7000-100NAS), but I think it's the same or a version of the AC1900 Netgear Nighthawk. All the documents I see...
cllinusa
Jan 08, 2017Tutor
Yes, you can setup a PC or more using VPN software on it, but you can't put your whole network on VPN because router doesn't do it. Considering this was a top rated (and expensive) router, it's unacceptable in my opinion
