Rickt1962
Nov 28, 2016Aspirant
Want to disable my wifi and add another unit
CG3000DV2 N450 has really bad wifi. So I want to be able to disconnect the wifi and add another Wifi which has AC/N which model should I get from Netgear that will plug into my N450 cable/router ?
TheEther
Nov 28, 2016Guru
Any router can be configured to operate as an Access Point. Most of Netgear's routers even have an AP Mode setting for convenience. It, then, comes down to your budget.
